Ping enhancement for IPv4 and IPv6 addresses
MVP
MVP
What are the latest enhancements to Ping feature and how to utilize them?
Starting 6.5.1.0, Ping will be supporting new features in addition to the existing ones. This include interval, pattern, timeout, tos, ttl and validate-reply. This will be available both on web UI as well as CLI. All the enhanced options support both IPV4 and IPV6.
INTERVAL:
Specifies the time gap between two subsequent ping datagrams. This ranges from 1 to 60 (in sec).
PATTERN:
Specifies the hexadecimal data pattern to be filled in the datagram. User can set up to 16 hexadecimal digits.
TIMEOUT:
Specifies the amount of time to wait for receiving response packet. This ranges from        1 – 10 (in sec). Default Value is 2 Sec.
ToS:
Specifies the Type-Of-Service value to be set in IP Header. This ranges from 0 – 255. The default value is 0.
TTL:
Specifies the Time-To-Live value to be inserted in the Ping request. This ranges from 1 – 255. The default value is 255.
VALIDATE-REPLY:
Specifies whether or not to validate the reply data. The default value is ‘no’.
No additional configuration is required for these features to work. Any controller running 6.5.1.0 and higher images should support them.
CLI
(Aruba7210) #ping 10.20.22.22 interval 1
Press 'q' to abort.
Sending 5, 92-byte ICMP Echos to 10.20.22.22, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1.213/3.749/9.764 ms.
(Aruba7210) #ping 10.20.22.22 pattern abcdef
Press 'q' to abort.
Sending 5, 92-byte ICMP Echos with pattern 0xabcdef to 10.20.22.22, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1.756/4.884/15.321 ms
(Aruba7210) #ping 10.20.22.22 timeout 1
Press 'q' to abort.
Sending 5, 92-byte ICMP Echos to 10.20.22.22, timeout is 1 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1.131/1.5205/2.547 ms
(Aruba7210) #ping 10.20.22.22 tos 255
Press 'q' to abort.
Sending 5, 92-byte ICMP Echos to 10.20.22.22, timeout is 2 seconds, tos value 0xff:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1.082/1.1124/1.187 ms
(Aruba7210) #ping 10.20.22.22 ttl 125
Press 'q' to abort.
Success rate is 100 percent (5/5), round-trip min/avg/max = 1.002/1.1554/1.335 ms
(Aruba7210) #ping 10.20.22.22 validate-reply
Press 'q' to abort.
Sending 5, 92-byte ICMP Echos to 10.20.22.22, timeout is 2 seconds, validate reply data set:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1.096/1.1978/1.416 ms
WebUI
Navigate to Diagnostics --> Ping
Version history
Revision #:
2 of 2
Last update:
‎02-20-2017 12:40 PM
Updated by:
Labels (1)
Contributors
