Provisioning rule configuration in Activate to terminate Branch Controller to Master Controller.
MVP
MVP
Q:
A:
Aruba Branch Office Controller can talk to activate and reach Master Controller to take up the configuration. This is called as Zero Touch Provisioning.
Before even this takes place, pre-configuration is required on activate account to setup the provisioning rule.  As shown in the below image, create a provisioning rule with the appropriate public IP address of the Primary Controller:
Version history
Revision #:
2 of 2
Last update:
‎03-24-2017 04:02 PM
Updated by:
Labels (1)
Contributors
