RADIUS accounting for open SSID
MVP
MVP
  • This request came from a requirement where we wanted to bill users who are connected to a specific open system SSID.
  • As a part of requirement Radius accounting feature can be enabled for user connecting to Open SSID
  • As per this implementation the Radius accounting has been extended to stations connecting to Open SSID  from 6.4.3.0 release.
  • The feature can be done by enabling the Open SSID accounting knob in AAA profile.
  • We support Radius Accounting Start, Interim & Stop messages.
TOPOLOGY:
Configurations Using CLI
Enable Open SSID Accounting:
# aaa profile Paaa
#open-system-radius-accounting
#show aaa profile Paaa
RADIUS Accounting Server Group      svrGrp
Open SSID radius accounting         Enabled
 Disable Open SSID Accounting:
# aaa profile Paaa
#no open-system-radius-accounting
WebUI:
  • Navigate to Configuration ->All Profile ->Select Wireless LAN
  • Select Specified aaa profile under AAA section
  • Enable “Open SSID accounting” knob in aaa profile
Enable Below Logs to get the accounting info in Security Logs:
#logging level debugging security
#logging level debugging security process authmgr subcat aaa
Show log security output:
Radius Accounting  Start Message details:
Logs
Radius Accounting  Stop  Message:
Radius interim accounting Message:
Auth-tracebuf output:
23:06:39  rad-acct-start        ->  00:1c:7b:9e:d9:3a  00:24:6c:80:42:c5/RADIUS  -  -
23:11:20  rad-acct-stop         ->  00:1c:7b:9e:d9:3a  00:24:6c:80:42:c5/RADIUS
23:25:45  rad-acct-int-update   ->  00:1c:7b:9e:d9:3a  00:24:6c:80:42:c5/RADIUS  -  -
Version history
Revision #:
2 of 2
Last update:
‎03-07-2016 01:32 PM
Updated by:
Labels (1)
Contributors
