RAP-3WNP is coming up as CAP though its provisioned as Cert-based RAP.
Environment Information- Network Setup:
Standalone Master with three RAP3WNP.
All three RAPs are connected to the Linksys Router.
Controller >> Firewall >> ISP >> Linksys Router >> RAP3WNP
AOS: 6.4.2.3
Symptoms-
RAP-3WNP is coming up as CAP when its provisioned as Cert-based RAP.
In #show ap database output we can see the RAP got inner IP address and it went down.
#show ap database
Fri Jan 16 14:58:35.144 2015
AP Database
Name           Group       AP Type   IP Address    Status     Flags  Switch IP    Standby IP
Kraton_RAP_03  Kraton_RAP  RAP-3WNP  1.1.1.2       Down       Rc2    10.208.4.38  0.0.0.0   ====================> RAP got inner IP address and rebooted.
show crypto isakmp sa peer 204.57.67.86
Fri Jan 16 14:56:52.404 2015
 Initiator IP: 204.57.67.86
 Responder IP: 10.208.4.38
 Initiator: No
 Initiator cookie:e03b0e59f9343018 Responder cookie:ff7b09bf1c440712
 SA Creation Date: Fri Jan 16 14:56:47 2015
 Life secs: 28800
 Initiator Phase1 ID: CN=BF0099183::00:0b:86:bb:4f:6e
 Responder Phase1 ID: CN=CR0001928::00:0b:86:b4:e7:77 L=SW
 Exchange Type: IKE_SA (IKEV2)
 Phase1 Transform:EncrAlg:AES256 HashAlg:HMAC_SHA1_96 DHGroup:2
 Authentication Method: RSA Digital Signature 2048-bits
 CFG Inner-IP 1.1.1.2
 IPSEC SA Rekey Number: 0
 Aruba AP
(Kraton_Aruba_7030) #show crypto  ipsec sa peer 204.57.67.86
Fri Jan 16 14:57:05.014 2015
 Initiator: No
 SA Creation Date: Fri Jan 16 14:56:48 2015
 Life secs: 7200
 Phase2 Transform:Encryption Alg: AES 256 Authentication Alg: SHA1
 Encapsulation Mode Tunnel
 PFS: no
 IN SPI: 70689000, OUT SPI: CB231800
In the user-table output we could see the RAP is falling into ap-role when it got valid inner IP address.
(Kraton_Aruba_7030) #show user-table verbose
Fri Jan 16 14:57:13.122 2015
Users
    IP              MAC            Name              Role           Age(d:h:m)  Auth    VPN link      AP name        Roaming   Essid/Bssid/Phy           Profile        Forward mode  Type   Host Name  Server       Vlan     Bwm  UaStr:ParseDisable/Flag/ShortIndex
204.57.67.86   00:00:00:00:00:00                     logon          00:00:03    VPN                   N/A                                                               tunnel                                       0 (0)         OFF/0/0
1.1.1.2        00:00:00:00:00:00  00:0b:86:bb:4f:6e  ap-role        00:00:00    VPN     204.57.67.86  N/A                                                default-rap    tunnel                          Internal     0 (0)         OFF/0/0
10.208.28.21   f8:16:54:90:d7:b0  KRATON\juknotts    authenticated  00:00:08    802.1x                Kraton_RAP_02  Wireless  WMS2/18:64:72:7a:a4:a1/g  Kraton_802.1x  tunnel        Win 7             10.208.9.77  29 (29)       OFF/0/14
172.31.98.163  f8:16:54:90:d7:b0  KRATON\juknotts    authenticated  00:00:02    802.1x                Kraton_RAP_02  Wireless  WMS2/18:64:72:7a:a4:a1/g  Kraton_802.1x  tunnel        Win 7             10.208.9.77  29 (29)       OFF/0/14
User Entries: 4/4
 Curr/Cum Alloc:3/4 Free:0/1 Dyn:3 AllocErr:0 FreeErr:0
In the security logs we see IPSEC SA is deleted due to invalid cookies.
Jan 16 14:56:47 :103078:  <INFO> |ike|  IKEv2 CHILD_SA successful for peer 204.57.67.86:49154
Jan 16 14:57:14 :103063:  <DBUG> |ike|  204.57.67.86:49154-> message_recv: invalid cookie(s) e03b0e59f9343018 ff7b09bf1c440712
Jan 16 14:57:14 :103060:  <DBUG> |ike|  204.57.67.86:49154-> message.c:message_drop:2886 Message drop from 204.57.67.86 port -16382 due to notification type INVALID_COOKIE
Jan 16 14:57:58 :103063:  <DBUG> |ike|   IPSEC_deleteSaByInnerIPExtIP delete IPSEC SA 204.57.67.86:(inner:1.1.1.2)
Jan 16 14:57:58 :103101:  <INFO> |ike|  IPSEC SA deleted for peer 204.57.67.86
Once the RAP is rebooted it came up as CAP.
#show ap database
Fri Jan 16 14:40:03.521 2015
AP Database
Kraton_RAP_03  Kraton_RAP  RAP-3WNP  204.57.67.86  Up 1h:38m:10s         10.208.4.38  0.0.0.0 ==============> After reboot the RAP came up as CAP.
Cause- In the ap-group the provisioning profile is set to default however there was no configuration done in the default provisioning-profile.
ap-group "Kraton_RAP"
   virtual-ap "Kra_Home"
   virtual-ap "WMS2"
   enet1-port-profile "wport_prof-mac33"
   enet2-port-profile "wport_prof-qfo99"
   enet3-port-profile "wport_prof-xsp49"
   enet4-port-profile "wport_prof-jgf16"
   ap-system-profile "apsys_prof-jxu94"
   voip-cac-profile "Kraton_RAP_VoIP_Call_Admission_Control"
   provisioning-profile "default"  ================================================>
IKE deletes the IKE/IPSEC SAs.
Jan 16 14:57:58  authmgr[3535]: <124220> <DBUG> |authmgr|  stm_message_handler : msg_type 3099
Jan 16 14:57:58  isakmpd[3399]: <103060> <DBUG> |ike|   ipc.c:ipc_rcvcb:1846 Auth ip down message.  ip=1.1.1.2
Jan 16 14:57:58  isakmpd[3399]: <103063> <DBUG> |ike|   IPSEC_deleteSaByInnerIPExtIP delete IPSEC SA 204.57.67.86:(inner:1.1.1.2)
Jan 16 14:57:58  isakmpd[3399]: <103101> <INFO> |ike|  IPSEC SA deleted for peer 204.57.67.86
Resolution- By removing the provisioning profile and re-provisioned it as RAP, it came up fine.
AP Database
Kraton_RAP_03  Kraton_RAP  RAP-3WNP  1.1.1.3       Up     4m:30s  Rc2    10.208.4.38  0.0.0.0  ==================> After re-provisioning it came up as RAP.
Answer- By removing the provisioning profile and re-provisioned it as RAP, it came up fine.
AP Database
Kraton_RAP_01  Kraton_RAP  RAP-3WNP  204.57.67.86  Down              10.208.4.38  0.0.0.0
Kraton_RAP_02  Kraton_RAP  RAP-3WNP  10.208.6.113  Up 39m:2s         10.208.4.38  0.0.0.0
Version history
Revision #:
1 of 1
Last update:
‎04-05-2015 11:13 PM
Updated by:
Labels (1)
Contributors
