Reason for Ekahau RTLS tags not working with newer APs
Question: What is the reason for the Ekahau RTLS tags not working for newer APs 225/275
Environment: This issue is seen on newer APs 225/275
Earlier the APs were sending the RTLS tag with two extra Bytes and the Ekahau configured the server to accept the 2 Bytes ( functionality no defined )
In the newer APs the two extra bytes are removed causing the Ekahau RTLS tags not to work.
In Aruba OS 6.3.1.10 and 6.4.2.0 a knob is added to add/remove the 2 bytes to make it work.
Version history
Revision #:
1 of 1
Last update:
‎08-14-2014 04:06 PM
Labels (1)
Contributors
