Reboot time for CPSEC and Remote AP's.
MVP
MVP
Q:
What is the approximate reboot time for CPSEC and Remote AP's?
A:
The maximum IPSEC retries done by the CPSEC APs are 30 and for the remote AP's its 85.
By default, the number of IPSEC retries are set to 85 and this parameter is configurable in AP system profile.
(Aruba) #show ap system-profile default | include IPSEC
Number of IPSEC retries                  85
When the number of IPSEC retries are set >= 30 then it will affect only the Remote AP's.
When the number of IPSEC retries are set < 30 then it will affect both CPSEC enabled Campus AP's and Remote AP's.
The approximately reboot time for CPSEC AP would be 30 mins and reboot time of Remote AP will be 85 mins.
Version history
Revision #:
2 of 2
Last update:
‎03-24-2017 03:52 PM
Updated by:
Labels (1)
Contributors
