Redistribution of static routes through ospf
MVP
MVP
Q:
A:
Redistribution of Static Routes over OSPF is needed when one or more static routes need to be propagated over OSPF. OSPF will only redistribute classful network routes by default. Static Routes redistributed to OSPF neighbor are marked External. It does not add internal link cost to the net route cost.
(A7220-VIG-2) [mynode] (config) #show ip route | i "S"
Codes: C - connected, O - OSPF, R - RIP, S - static
       M - mgmt, U - route usable, * - candidate default, V - RAPNG VPN/Branch
S*    0.0.0.0/0  [1/0] via 2.2.2.1*
S    192.168.1.0/24 [1/0] via 2.2.2.1*
S    192.168.2.0/24 [1/0] via 2.2.2.1*
S    192.168.3.0/24 [1/0] via 2.2.2.1*
S    192.168.4.0/24 [1/0] via 2.2.2.1*
S    192.168.5.0/24 [1/0] via 2.2.2.1*
(A7220-VIG-2) [mynode] (config) #show configuration committed | include router
router ospf router-id 10.8.220.2
router ospf
router ospf area 0.0.0.0
(A7220-VIG-2) [mynode] (config) #show ip ospf neighbor
OSPF Neighbor Table
Neighbor ID  Pri  State      Address   Interface
6.6.6.1      1    FULL/BDR   2.2.2.4   Vlan 2
(A7220-VIG-2) [mynode] (config) #router ospf redistribute static
<cost>                  Route metric <0-16777215>
(A7220-VIG-2) [mynode] (config) #router ospf redistribute static 1
(A7220-VIG-2) ^[mynode] (config) #write mem
(A7005-1-R13) #show ip ospf neighbor
OSPF Neighbor Table
10.8.220.2   1    FULL/DR   2.2.2.2   Vlan 2
(A7005-1-R13) #
(A7005-1-R13) #show ip ospf debug route
192.168.1.0   255.255.255.0   2.2.2.2   2     STUB_NET   1        TYPE_2_EXT
192.168.2.0   255.255.255.0   2.2.2.2   2     STUB_NET   1        TYPE_2_EXT
192.168.3.0   255.255.255.0   2.2.2.2   2     STUB_NET   1        TYPE_2_EXT
192.168.4.0   255.255.255.0   2.2.2.2   2     STUB_NET   1        TYPE_2_EXT
192.168.5.0   255.255.255.0   2.2.2.2   2     STUB_NET   1        TYPE_2_EXT
(A7005-1-R13) #
Version history
Revision #:
2 of 2
Last update:
‎04-23-2017 12:07 AM
Updated by:
Labels (1)
Contributors
