Requirements for forming a cluster & Capacity per platform.
MVP
MVP
Q:
What is the cluster capacity in homogeneous vs heterogeneous environment ?
A:
The following controllers can be part of the cluster.
  • 72xx controllers
  • 70xx controllers
  • Virtual Mobility Controllers (VMC)
Note: All the managed nodes need to run the same version of software (8.0 & higher).
Cluster Capacity Per Platform:
  • We can have up to 12 mobility controllers in a cluster when using 72xx.
  • We can have up to 4 mobility controllers in a cluster when using 70xx.
  • We can have up to 4 VM's in a cluster when using Virtual Mobility Controllers (VMC).
  • A mix of hardware (7xxx) and x86 Mobility Controllers in the same cluster is not supported
  • Heterogeneous nodes can’t be more than 4 nodes in size (mix of 70xx & 72xx).
Version history
Revision #:
1 of 1
Last update:
‎03-21-2017 12:22 PM
Updated by:
