Seamless Logon in AOS8.x
MVP
MVP
Q:
What is Seamless Logon in AOS 8.x?
A:
The Seamless Logon feature enables you to login from the Mobility Master to a managed device without entering a password. The user can remotely login from a centralized location (Mobility Master) to any managed device and execute the show and action commands.
(MM) [mynode] #show switches
All Switches
IP Address     IPv6 Address  Name      Location          Type    Model      Version        Status  Configuration State  Config Sync Time (sec)  Config ID
10.17.164.237  None          MM        Building1.floor1  master  ArubaMM    8.0.1.0_57204  up      UPDATE SUCCESSFUL    0                       7
10.17.169.71   2001::1       A7030     Building1.floor1  MD      Aruba7030  8.0.1.0_57204  up      UPDATE SUCCESSFUL    0                       7
Total Switches:2
(MM) [mynode] #logon 10.17.169.71
Last login: Fri Feb 17 15:28:06 2017 from 10.17.164.237
(A7030) [MDC] *#show switches
All Switches
10.17.169.71  2001::1       A7030  Building1.floor1  MD    Aruba7030  8.0.1.0_57204  up      UPDATE SUCCESSFUL    10                      7
(A7030) [MDC] *#show loginsessions
Session Table
ID  User Name       User Role  Connection From  Idle Time  Session Time  Path
1   seamless-logon  read-only  10.17.164.237    00:00:03   00:00:10      /
2   admin           root       10.240.120.27    00:21:39   00:32:03      /
(A7030) [MDC] *#exit
(MM) [mynode] #
Version history
Revision #:
1 of 1
Last update:
‎04-02-2017 11:09 PM
Updated by:
