Separate view of g" and "a" clients connected to the controller
Controller generally displays both the authenticated "g' and "a" clients on  the controller from # show user command and when there are huge number of clients on the controller the below commands help you to separately view the g/a clients on the controller; another advantage over this command is reduce the cpu utilization on the controller since #show user displays the entry for both the phy-type.
(Aruba7210) #show user-table
Users
    IP           MAC            Name     Role           Age(d:h:m)  Auth  VPN link  AP name            Roaming   Essid/Bssid/Phy                  Profile  Forward mode  Type  Host Name
172.16.0.1  00:27:10:35:ae:1c            authenticated  00:00:00                    9c:1c:12:c3:97:60  Wireless  manoj-ap/9c:1c:12:b9:76:10/a-HT  default  tunnel
172.16.0.2  f0:dc:e2:67:de:6d            authenticated  00:00:00                    9c:1c:12:c3:97:60  Wireless  manoj-ap/9c:1c:12:b9:76:00/g-HT default  tunnel
User Entries: 2/2
 Curr/Cum Alloc:2/11 Free:0/9 Dyn:2 AllocErr:0 FreeErr:0
(Aruba7210) #show user-table phy-type a
Users
User Entries: 1/1
(Aruba7210) #show user-table phy-type g
Users
User Entries: 1/1
Version history
Revision #:
1 of 1
Last update:
‎06-30-2014 05:30 PM
Updated by:
Labels (1)
Contributors
