Things to be checked when mDNS Process Consumes 100% CPU utilization
Q:
A:
The mDNS process could consume 100% CPU utilization because of multiple reasons. To diagnose why the mDNS process consumes 100% CPU utilization, perform the following checks:
1: Check the status of the current credits by issuing the show airgroup global-credits command.
The following is the sample output of the show airgroup global-credits command where the current credits are high:
(host) #show airgroup global-credits
Global Credits - Default
Type                                            Value
Query Packets                      800
Response Packets               300
Global Credits - Current
Type                                            Value
Query Packets                      30
Response Packets               10
Note
The credits are used within a predefined time window. For example, if the credits are set to 900 and 300 for query packets and response packets respectively, they are used within 30 seconds (predefined time window). At the end of the predefined time window, the credits are renewed and are available for the next predefined time window. Based on the rate of queries and responses, the credits could be used unevenly within the predefined time window. This may lead to the availability of high credits for the remaining time of the predefined time window which may lead to higher CPU utilization.
2:If the current credits are high, reconfigure the credits by issuing the airgroup global-credits command in the config mode.
The following is the output of the airgroup global-credits command:
(host) #configure terminal
(host) (config) #airgroup global-credits 700 200
The following is the sample output of the show airgroup global-credits command after reconfiguring the credits:
Type                                            Value
Query Packets                      700
Response Packets               200
Type                                            Value
Query Packets           50
Response Packets        30
3: Check if the allowall service or Any undesired services are enabled .
(host) #show airgroup status
AirGroup Feature
Status
Enabled
AirGroup- MDNS Feature
Status
Enabled
AirGroup- DLNA Feature
Status
Enabled
AirGroup Location Discovery
Status
Enabled
AirGroup Active Wireless Discovery
Status
Enabled
AirGroup Enforce Registration
Status
Disabled
AirGroup IPV6 Support
Status
Disabled
AirGroup Service Information
Service     Status
airplay     Enabled
airprint    Enabled
itunes      Enabled
remotemgmt  Disabled
sharing     Disabled
chat        Disabled
googlecast  Enabled
DIAL        Enabled
DLNA Media  Disabled
DLNA Print  Disabled
allowall    Disabled
clearpass   Enabled
4:Disable any undesired service by issuing the airgroup service <service name> disable command in the config mode (where <service name> is the name of the undesired service).
 Eg
(host) (config) #airgroup service itunes disable
5:Enable location policies on the servers for efficient cache management by issuing the autoassociate command for the desired service in the config mode.
The following is the sample output of the autoassociate command for the airplay service:
(host) (config) #airgroupservice airplay
(host) (config-airgroupservice) #autoassociate
If not Use CPMM to Actively manage the devices with the location policies.
Version history
Revision #:
2 of 2
Last update:
‎11-25-2015 04:05 PM
Updated by:
Labels (1)
Contributors
