Troubleshooting AP Rebootstrap Related Issues
The follwoing URL describes the AP troubleshooting best practices and provides guidance for initial debugging on AP rebootstrap-related issues. It also provides detailed step-by-step information on how to debug the most common issues.
http://www.arubanetworks.com/techdocs/Troubleshooting/ArubaOS/AP_Rebootstrap/Web_Help_Index.htm
Version history
Revision #:
5 of 5
Last update:
‎06-25-2015 11:00 AM
Updated by:
Labels (1)
Contributors
Comments
ummmmbeer
HELP! I have taken 2 APs offline for relocation. The one with the virtual controller is a instaon 93, there are 2 other 103 units. I took the 93 and one 103 offline then plugged them back in and only the 93 worked. I reset the 93 to factory then rebuilt config. The 103 that had not been moved showed up. The other I reset. No joy. I took all 3 offline then reset the 93 redid config (from scratch) then powered up the 103 that originally worked no joy. Tried everyhing help me!
