Troubleshooting AirGroup
AirGroup is an enterprise-class solution that leverages Bonjour-based services like Apple AirPrint or AirPlay and DLNA-based services from wireless and wired devices to communicate over complex networks. Bonjour-based and DLNA-based services are essential services in campus networks. Sometimes, AirGroup may present error scenarios or not work as desired. Use the following sections to identify, diagnose, and correct AirGroup error scenarios.
The follwoing URL describes the AirGroup troubleshooting best practices and provides guidance for initial debugging.
http://www.arubanetworks.com/techdocs/Troubleshooting/ArubaOS/AirGroup_Troubleshooting/Web_Help_Index.htm
Version history
Revision #:
1 of 1
Last update:
‎09-21-2015 02:05 AM
Updated by:
Contributors
Tags (1)
