Unable to clear the contents of Whitelist-db using purge command.
Q:
Why am I unable to delete the contents of RAP whitelist-db from the controllers when I execute the purge command?
(master) #whitelist-db rap purge
After some time, I see the RAP whitelist get populated again.
A:
To purge the RAP whitelist, we can execute the command:
However this will only work on a standalone controller and not an a controller which is part of a master/standby-local cluster. The controller which is part of a cluster will have its whitelist-db repopulated again from the other member of the cluster.
This is recommended command to be executed on a new controller before we add the controller to an existing master-local setup to prevent the whitelist-db corruption.
Version history
Revision #:
2 of 2
Last update:
‎06-15-2015 05:08 AM
Updated by:
Labels (1)
Contributors
