Visualrf Planner issue with IE
Question : What can we do when the visualrf planner tool is not getting saved in .exe format when downloaded using IE
Environment Information : Visualrf Planner tool 7.7
Window 7,8
Internet explorer
Symptoms : When we download visualrf planner tool using IE , it wont be saved in .exe format. When we try to change the format manually, it will give us an error "File already opened in IE cannot make the change"
Resolution : As a resolution we can follow the below steps while downloading the file using IE..
  • Initiate the download using IE
  • "Save as"  the file with file type as "All files"
  • Then rename the file to .exe format after download.
Version history
Revision #:
1 of 1
Last update:
‎07-14-2014 01:23 AM
Updated by:
Labels (1)
