Controller Based WLANs
last person joined: one year ago
APs, Controllers, VIA
WHEN AND WHEN NOT PIN IS NEEDED WHILE AUTHENTICATING VIA USING SMART CARD
Jul 03, 2014 05:50 PM
Environment  :  ARUBA OS
CASES WHEN PIN IS NEEDED
1) The certificate selected is coming from the smart card.
2) The smart card is protected by PIN.
3) User did not supply PIN from the start of the Application.
4) User cleared certificate selection from connection profile/ VIA client
5 )User removes and insert the card again
6) User reboot the client machine
CASES WHEN PIN IS NOT NEEDED
1) Selected certificate is not coming from a smart card.
2) The smart card is not protected by PIN.
3) User has supplied the PIN and the card is not removed and
reinserted in last 30 minutes (time out period depends on smart
card  or reader settings)
4: User disconnect and reconnect the VIA within the expiry time (default 30 min) on the smart card.
Statistics
0 Favorited
0 Files
0 Shares
0 Downloads
Related Entries and Links
No Related Resource entered.
