Web UI absolute session timeout on controller
Can we configure Web UI absolute session timeout on controller?
This article is applicable to controller running OS.
Absolute session timer will take affect from the session initialization itself.  Session will be timed-out and cleared once system time has passed absolute timeout duration after the session initialization. WebUI Absolute Session timer is Disabled by default.
web-server profile
  absolute-session-timeout <30-3600> (seconds)
(C1) (Web Server Configuration) #show web-server profile
Parameter                                          Value
Cipher Suite Strength                              high
SSL/TLS Protocol Config                            tlsv1 tlsv1.1 tlsv1.2
Switch Certificate                                 default
Captive Portal Certificate                         default
IDP Certificate                                    default
Management user's WebUI access method              username/password
User absolute session timeout <30-3600> (seconds)  3600 >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
User session timeout <30-3600> (seconds)           60
Maximum supported concurrent clients <25-320>      50
Enable WebUI access on HTTPS port (443)            true
Web Skype4B Listen Protocol/Port Config            N/A
Enable bypass captive portal landing page          false
Version history
Revision #:
2 of 2
Last update:
‎11-25-2015 04:01 PM
Updated by:
Labels (1)
