What are the default DSCP-WMM mapping for Lync deployments?
Environment  :  AOS - LYNC integration
If no DSCP value is configured on the controller, Lync VO/ VI traffic will be marked with default DSCP Tags. The default DSCP tag for Lync heuristics is as follows:
Version history
Revision #:
1 of 1
Last update:
‎07-10-2014 03:21 PM
Updated by:
Labels (1)
Contributors
Comments
Note that Default DSCP tag for VO for Lync SDN API based deployment is DSCP 56.
