What are the limitation in custom cert for Remote Ap's ?
Certificate renewal/reenrollment is not supported in this version
Configuring multiple CA URL’s is not possible in current version
This feature is not supported for CAPs.
EC Certificates are not supported. Works only with RSA-SHA1.
CSR parameters are currently not configurable. We use same CSR generation method used for generating field certificates.
Version history
Revision #:
1 of 1
Last update:
‎11-04-2014 04:08 PM
Updated by:
