What causes the internal system error at filpair.c: ?function rc_avpair_add_str line 24 error Bad name length??
Product and Software: This article applies to all Aruba controllers running ArubaOS 3.0 and later.
If the RADIUS server returns an attribute with a length greater than 32 bytes, the controller produces this error message.
To determine which attribute value length is greater than 32 bytes, start a packet capture on the controller to sniff UDP packets to and from the RADIUS server on the configured port and monitor the logs for the error message.
Also note the timestamp of the error log and then cross-check the captured packets at the same time the error was logged.
Version history
Revision #:
1 of 1
Last update:
‎07-05-2014 03:44 AM
Updated by:
Labels (1)
