What does the BC / MC rate optimization do?
Here are a few facts about this option:
·   The option 'mcast-rate-opt' was added to the ssid profile in version 3.2 and higher.
·   It is disabled by default
·   By default, Broadcasts and Multicasts are transmitted by an AP at the lowest configured rate, i.e 1 Mbps in the g band and 6 Mbps in the a band.
·   When this option is enabled, the bcast/mcast data frames are transmitted at the lowest of the unicast tx rates across all the associated stations.
·   Management frames tx rate remains unchanged.
Version history
Revision #:
1 of 1
Last update:
‎07-10-2014 09:46 AM
Updated by:
Labels (1)
