What does the message "MAX Entries reached" mean?
Product and Software: This article applies to all Aruba controllers and ArubaOS 3.x.
The log message indicates that the internal tree data structures that are  used to maintain information about monitored APs and monitored stations  have reached maximum capacity, and no more entries are being added. This can  be seen using the 'show wms counters' command.
Version history
Revision #:
1 of 1
Last update:
‎07-10-2014 10:09 AM
Updated by:
Labels (1)
Contributors
