What is EAPOL rate optimization and how to configure it
There are 4 EAPOL Keys that are exchanged between AP & Client during the WPA/WPA2 Handshake
PSK:
The EAPOL keys that are sent from AP to the Client are sent at 11n rates when optimization is disabled
The EAPOL keys that are sent from AP to the Client are sent at 24Mbps when optimization is enabled
802.1x Authentication:
The EAPOL Request/Response & EAPOL keys that are sent from AP to the Client are sent at 11n rates when optimization is disabled
The EAPOL Request/Response & EAPOL keys that are sent from AP to the Client are sent at 24Mbps when optimization is enabled
Enable EAPOL Rate Optimization
(Seraph_Master) (SSID Profile "default") #eapol-rate-opt
Disable EAPOL Rate Optimization
(Seraph_Master) (SSID Profile "default") #no eapol-rate-opt
Version history
Revision #:
1 of 1
Last update:
‎04-07-2015 01:31 PM
Updated by:
Labels (1)
Contributors
