Prior to AOS version 6.3.0.0, the delay in association/re-association between a client and the APs was minimized by mechanisms like PMK caching and Opportunistic Key Caching (OKC).Below is a brief description of PMK Caching and OKC before we proceed with understanding IEEE 802.11r standards-
However, from version 6.3.0.0 onwards, Aruba now implements Fast BSS Transition (IEEE 802.11r) to reduce the delay caused due to re-authentication, every time a client roams from one AP to another. In an 802.11r environment, the FT mechanism allows a client station to establish security and/or QoS state at the target AP prior to or during re-association. This reduces the delay in connecting to the distribution system after transition.As of AOS version 6.3.0.0, Fast Transition roaming is only supported between APs in the same Mobility Domain on the same controller. We can configure the mobility domain in the 80.211r profile and map it under the SSID profile on the controller. Hence, all the clients connecting to the same SSID roaming across multiple APs on the same controller are a part of the same Mobility Domain.Difference between Fast BSS Transition and OKC:
Fast Transition Key Hierarchy – WLAN ControllerThere are three levels in the FT key hierarchy for controller:
Fast Transition Key Hierarchy – Supplicant There are three levels in the FT key hierarchy for a client supplicant:
