What is IF-MAP and how is it configured on controller ?
This article applies to Aruba Mobility Controllers.
MAPC (Metadata Access Point Client)
MAP (Metadata Access Point)
IF-MAP provides publish, subscribe, and search interfaces between MAP Clients and MAP to share and correlate runtime metadata. A “metadata” is any shared real time data about network devices, policies, status, behavior etc
In AOS 6.3, both http-user-agent string used in client devices and mDNS service announcement information received will be published to CPPM.
Below image shows the configuration on the controller:
User-added image
Version history
Revision #:
1 of 1
Last update:
‎06-26-2014 01:55 PM
Updated by:
Labels (1)
Contributors
