What is Mute AP Radio?
MVP
MVP
Q:
A:
Starting from 8.3.0.2 code version, the rf dot11a-radio-profile and rf dot11g-radio-profile commands include the am-tx-mute parameter. Enable the amtx-mute parameter to prevent an AP that operates in the AM or spectrum mode from creating spurious transmissions during AP boot. By default, the am-tx-mute is disabled.
Enable the am-tx-mute parameter in the rf dot11a-radio-profile or rf dot11g-radio-profile command only for APs that operate in the AM or spectrum mode.
To enable the am-tx-mute parameter:
(host) (config) #rf dot11a-radio-profile default
(host) (config) (rf dot11a-radio-profile "default")#am-tx-mute
Version history
Revision #:
2 of 2
Last update:
4 weeks ago
Updated by:
Labels (1)
Contributors
