What is PAPI timeout error on port 8224
"PAPI_Send: To: 7f000001:8224 Type:0x4 Timed out" Errors on master controller
On the controller error and system logs below syslog message would pop.
Mar 31 23:54:16  snmp[1707]: PAPI_Send: To: 7f000001:8224 Type:0x4 Timed out.
we are seeing this log because an external SNMP poller is polling WMS tables,  and at times, WMS is busy and is not responding fast enough to the message from
the SNMP process. Since there are retries both for the message and for the SNMP query, the log is most likely not indicating any serious issue.
We need to check the below:
1. How frequently SNMP is device is polling the controller
2. Is there any indication that the SNMP polling is not working?
Version history
Revision #:
1 of 1
Last update:
‎11-11-2014 12:42 PM
Updated by:
Labels (1)
Contributors
