What is server load balancing and how to enable it
Question
What is server load balancing and how to enable it?
Answer
Environment: Aruba os 6.4 and above
This is a new feature introduced only from 6.4 code version.
How it works.
Load balancing of authentication servers ensures that the authentication load is split across multiple authentication servers, thus avoiding any one particular authentication server from being overloaded.
This prevents any one authentication server from having to handle the full load during heavy authentication periods.
Earlier, the controller used the first authentication server in the server group list. The remaining servers in that server group will be used in sequential order only when an authentication server is down.
The load balancing algorithm computes the expected time taken to authenticate a new client for each authentication server and chooses that authentication server for which the expected authentication time is
least.
The load balancing algorithm maintains re-authentication stickiness i.e. at the time of re-authentication the request will be forwarded to the same server where it was authenticated earlier.
How to Enable the Load balancing from CLI/WEBUI
(kuv_sek_7210_master) # show aaa authentication-server radius.
RADIUS Server List
Name       References Profile Status
KT_CPPM_1  5
KT_CPPM_2  4
win_rad    0
Total:3
(kuv_sek_7210_master) # show aaa server-group Guest25
Fail Through:No
Load Balance:No
Auth Servers
Name       Server-Type  trim-FQDN  Match-Type  Match-Op  Match-Str
KT_CPPM_1  Radius       No
KT_CPPM_2  Radius       No
Role/VLAN derivation rules
Priority  Attribute  Operation  Operand  Type  Action  Value  Validated
(kuv_sek_7210_master) #configure terminal
(kuv_sek_7210_master) (config) # aaa server-group Guest25
(kuv_sek_7210_master) (Server Group "Guest25") #load-balance
Fail Through:No
Load Balance:Yes
Auth Servers
KT_CPPM_1  Radius       No
KT_CPPM_2  Radius       No
Priority  Attribute  Operation  Operand  Type  Action  Value  ValidatedYou can use the following command to disable load balancing:
aaa server-group<sg_name>
no load-balance
Use the following command to disable it.
(kuv_sek_7210_master) (Server Group "Guest25") #no load-balance
NOTE:
If you configure internal server in the server group, load balancing is not applicable to the internal server. Internal
Server will be used as fall back when all the other servers in the server group are down.
From Webui
Version history
Revision #:
3 of 3
Last update:
‎11-09-2014 12:04 AM
Labels (1)
Contributors
Comments
madmerlin
How does it do the load-balancing?  We have 2 CPPM servers configured to load balance but on certain days, the load of requests is far from equal?  They are on different location.
Are there commands to check how it favored the other CPPM?  What are the factors that the controller use?
Thank you.
