What is the AP Capacity Per Controller with ArubaOS 6.2.0.0 ?
Question What is the AP Capacity Per Controller with ArubaOS 6.2.0.0 ?
Environment This article applies to all Aruba Mobility Controller running a minimum OS version of Aruba OS 6.2.0.0
Starting with ArubaOS 6.2.0.0, controllers support the following number of APs. Consider the following limits when upgrading to ArubaOS 6.2 or later
ControllerTotal AP CountCampus APsRemote APs
7240 2048 2048 2048
7220 1024 1024 1024
7210 512 512 512
M3 1024 512 1024
3600 512 128 512
3400 256 64 256
3200XM 128 32 128
650 16 16 16
620 8 8 8
Version history
Revision #:
1 of 1
Last update:
‎07-10-2014 01:42 PM
Labels (1)
Contributors
