What is the Default bootstrap threshold for Remote AP and Campus APs?
Environment : This article applies to all OS Versions
Even if the bootstrap threshold parameter in the AP system profile is set to a low value, the default minimum bootstrap-threshold value for RAPs is 30. The bootstrap-threshold for CAPs can be set to a minimum of 1. The default (recommended) bootstrap-threshold value for CAPs is 8.
To Change the bootstrap threshold, navigate to Configuration> AP Configuration> Edit the APGroup> AP> AP System Profile and change the bootstrap threshold.
Version history
Revision #:
1 of 1
Last update:
‎06-29-2014 10:01 AM
Updated by:
