What is the default ipsec-map 'Priority' for Master-Standby and Master-Local?
Product and Software: This Article applies to all Aruba Wireless Controller and Aruba OS.
The default IPsec-map priority used for Master-Local and Master-Standby is '9999'
(Aruba-Master) #show switches
All Switches
IP Address       Name                                   Location              Type               Model               Version                    Status     Configuration State            Config Sync Time (sec)     Config ID
10.10.10.10     Aruba-Master                      Building1.floor1   master         Aruba7220       6.3.1.2_41362       up             UPDATE SUCCESSFUL   0                                             1
10.10.10.11     Aruba-Local                        Building1.floor1   local              Aruba3400      6.3.1.2_41362        up            UPDATE SUCCESSFUL    7                                             1
10.10.10.12     Aruba-Backup                      Building1.floor1   standby        Aruba3600      6.3.1.2_41362        up            UPDATE SUCCESSFUL    17                                           1
(Aruba-Master) #show crypto-local ipsec-map
Crypto Map Template"default-local-master-ipsecmap10.10.10.11" 9999
         IKE Version: 1
         IKEv1 Policy: All
         Security association lifetime seconds : [300 -86400]
         Security association lifetime kilobytes: N/A
         PFS (Y/N): N
         Transform sets={ default-ml-transform }
         Peer gateway: 10.10.10.11
         Interface: VLAN 0
         Source network: 0.0.0.0/0.0.0.0
         Destination network: 10.10.10.11/255.255.255.255
         Pre-Connect (Y/N): N
         Tunnel Trusted (Y/N): Y
         Forced NAT-T (Y/N): N
Crypto Map Template"default-psk-redundant-master-ipsecmap" 9999
         IKE Version: 1
         IKEv1 Policy: All
         PFS (Y/N): N
         Peer gateway: 10.10.10.12
         Interface: VLAN 0
         Source network: 10.10.10.10/255.255.255.255
         Destination network: 10.10.10.12/255.255.255.255
         Pre-Connect (Y/N): Y
NOTE: For manual ipsec-map priority we have below entry.
(Aruba-Master) (config) #crypto-local ipsec-map test-lab ?
<ipsec-map-number>      [1 - 9998] - Priority of the entry
Version history
Revision #:
1 of 1
Last update:
‎07-04-2014 02:11 PM
Updated by:
Labels (1)
Contributors
