What is the expected mesh performance across each hop in a mesh setup?
Product and Software: This article applies to all Aruba controllers and ArubaOS 3.x.
As a rule of thumb, you can normally halve the speed across each hop. So performance is ½ after the first hop, ¼ after the second hop, and so on.
The maximum hop count suggested is four hops.
Version history
Revision #:
1 of 1
Last update:
‎07-09-2014 02:56 PM
Updated by:
Labels (1)
Contributors
