Controller Based WLANs
last person joined: one year ago
APs, Controllers, VIA
What is the hexkey and passphrase for WEP and TKIP?
Jul 09, 2014 06:10 PM
Product and Software: This article applies to ArubaOS 2.5.x.
On the controller with encrypt disabled, issue the following command:
# show dot1x ap-table Static-wep
Static-WEP Key Information
AP-MAC Key1/Size Key2/Size Key3/Size
00:0b:86:c1:ad:68 12:34:56:78:90/40-Bit(T) Key Not Set Key Not Set
00:0b:86:c1:ad:60 12:34:56:78:90/40-Bit(T) Key Not Set Key Not Set
This output shows the passphrase and the corresponding converted hexkey for WEP in brackets ().
If you have a passphrase, you can find the corresponding hexkey from this link:
http://www.wifizard.com/wi-fi/convert.htm
You can also find out the WPA pre-shared keys for all the APs by issuing the following command:
# show dot1x ap-table Tkip
AP Table Showing TKIP Keys
AP-MAC GTK/Size/Slot
00:0b:86:c1:ad:68 (arubaaruba)7e:ba:cb:7b:43:7d:6b:29:05:45:98:8f:83:de:66:37:a
8:b3:b7:8f:96:cd:75:d9: a5:63:bd:cc:a8:77:4a:81/256-Bit/1
00:0b:86:c1:ad:60 (arubaaruba)ad:6f:ad:7b:f9:c2:8f:98:bc:26:90:43:3a:1b:b2:11:f
9:75:e5:05:ab:ef:f9:49:6e:b3:34:9b:27:63:02:a7/256-Bit/1
Statistics
0 Favorited
0 Files
0 Shares
0 Downloads
Related Entries and Links
No Related Resource entered.
