What is the maximum number of VRRP instances on M3/6000?
QuestionWhat is the maximum number of VRRP instances on M3/6000?
Aruba has tested 64 VRRP instances on Aruba M3/6000.
Having too many VRRP instances can cause memory / instability issue. If we do need more redundancy, we can have the VRRP redundancy on the uplink switches.
Please refer to : http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/VRRP-scaling/m-p/23410#M1395
Version history
Revision #:
1 of 1
Last update:
‎07-08-2014 02:51 PM
Labels (1)
Contributors
