What is the radiation pattern for AP-105 when it is deployed in horizontal or vertical directions?
Product and Software: This article applies to all Aruba controllers and ArubaOS version 3.4.1.x and later.
AP-105 uses an omnidirectional antenna that provides similar radiation pattern whether it is placed horizontally or vertically. AP-105 radiates signal in a 360-degree horizontal radiation pattern when placed horizontally or vertically. These APs are used when coverage is required in all directions (horizontally) from the antenna with varying degrees of vertical coverage. The following figure shows the radiation pattern of AP-105 when it is deployed in horizontal or vertical directions.
1382 image 1
Ask a local Sales Engineer to do a site survey to get the best deployment directions.
Version history
Revision #:
1 of 1
Last update:
‎07-02-2014 06:01 PM
Updated by:
Labels (1)
Contributors
