What is the restriction and config difference for cellular-handoff-assist on AOS: 6.4 over AOS: 6.5?
MVP
MVP
What is the configuration difference and restriction for cellular-handoff-assist on AOS: 6.4 over AOS: 6.5? How is it configured?
Aruba Mobility Controllers running minimum AOS: 6.4 or above
cellular-handoff-assist:
The cellular-handoff-assist is a feature that helps the 3G/4G capable Wi-Fi devices such as iPhone, iPad or Android clients who are at the edge of Wi-Fi network coverage switch from Wi-Fi to alternate 3G/4G radio that provides better network access.
Configuration difference and restriction on AOS: 6.4 over AOS: 6.5
The configuration difference is the cellular-handoff-assist feature is restricted to a RF profile(ARM) that applies to all the SSIDs in an AP Group and cannot be customized to a specific SSID. But from AOS: 6.5 onwards cellular-handoff-assist feature can be customized on per SSID(VAP) basis.
Configuration in AOS: 6.4
Through Web User Interface:
Through Command LIne Interface
To Enable:
(Master) #configure terminal
Enter Configuration commands, one per line. End with CNTL/Z
(Master) (config) #rf arm-profile Test-Profile-6.4
(Master) (Adaptive Radio Management (ARM) profile "Test-Profile-6.4") #cellular-handoff-assist
To Disable:
(Master) (Adaptive Radio Management (ARM) profile "Test-Profile-6.4") #no cellular-handoff-assist
Configuration in AOS: 6.5
Through Command Line Interface:
To Enable:
(Master) (config) #wlan virtual-ap Test-Profile
(Master) (Virtual AP profile "Test-Profile") #cellular-handoff-assist
To Disable:
(Master) (Virtual AP profile "Test-Profile") #no cellular-handoff-assist
On AOS 6.4
(Output Truncated)
(Master) #show rf arm-profile Test-Profile-6.4
Parameter        Value
Assignment        single-band
Allowed bands for 40MHz channels                            a-only
80MHz support                                                              Enabled
Client Aware        Enabled
Max Tx EIRP        127 dBm
Min Tx EIRP        9 dBm
Rogue AP Aware                                                             Disabled
Cellular handoff assist                                                   Enabled
Client Match        Enabled
Client Match report interval (sec)                                           30
On AOS 6.5
(Output Truncated)
(Master) #show wlan virtual-ap Test-Profile
Parameter                                       Value
AAA Profile                                     test-aaa
802.11K Profile                                 default
Hotspot 2.0 Profile                             N/A
SSID Profile                                    PavanTest
Virtual AP enable                               Enabled
Version history
Revision #:
4 of 4
Last update:
‎03-24-2017 04:47 PM
Updated by:
Labels (1)
Contributors
