What maximum password length is supported by Aruba for any PAP authentication?
Product and Software: This article applies to all Aruba controllers and ArubaOS versions.
The maximum length of the PAP password that Aruba supports is 49 characters.
Beyond 49 characters, the authentication fails with any authentication server (internal database or RADIUS or LDAP).
Version history
Revision #:
1 of 1
Last update:
‎07-05-2014 09:56 AM
Updated by:
Labels (1)
Is there anyway to up the character limit?
