To view the stats of the APs and clients connected to the managed controllers in Mobility Master dashboard
To achieve this we need to configure Mobility master as MON receiver or as the Airwave server
#mgmt-server primary-server <ip address of MM> profile default-amp
(MM) [md] (config) #mgmt-server primary-server 10.17.164.196 profile default-amp
or
#mgmt-server primary-server <ip address of MM> profile default-controller
(MM) [md] (config) #mgmt-server primary-server 10.17.164.196 profile default-controller
(MM) [md] (config) #mgmt-server primary-server 10.17.164.196 profile default-controller (MM) [md] (config) #write memory
Saving Configuration...
Partial configuration for /md ------------------------------------ Contents of : /flash/config/partial/50/p=md.cfg [FILE_INFO] /sc 50
On Managed node CLI
(MD) #show mgmt-servers
List of Management Servers -------------------------- Primary Server Profile Transport-method -------------- ------- ---------------- 10.17.164.196 default-controller udp Num Rows:1
(MD) #show mgmt-server profile default-controller
Mgmt Config profile "default-controller" (Predefined (changed)) --------------------------------------------------------------- Parameter Value --------- ----- Stats Enabled Tag Enabled Sessions Enabled Monitored Info - Add/Update Disabled Monitored Info - Deletion Disabled Monitored Info - Periodic Snapshot Disabled Wireless IDS Event Info Disabled Misc Enabled Location Enabled UCC Monitoring Enabled AirGroup Info Enabled Inline DHCP stats Enabled Inline AP stats Enabled Inline Auth stats Enabled Inline DNS stats Enabled
