What should I know about OSPF in Aruba products?
Product and Software: This article applies to all Aruba controllers and ArubaOS versions 5.x and later.
  • OSPF is disabled by default.
  • Aruba controllers support only one OSPF instance.
  • Maximum OSPF routes is 1K.
  • Convergence takes between 5 and 15 seconds.
  • Only stub and totally stub areas are supported.
  • Only one area can be configured.
  • Aruba controller cannot act as an area border router (ABR) or autonomous system border router (ASBR).
  • OSPF packets use generic routing encapsulation (GRE) over Internet Protocol Security (IPsec) tunnels. A Layer 3 GRE tunnel is configured between two routers with GRE destination addresses as the inner address of the IPsec tunnel. OSPF is enabled on the Layer 3 GRE tunnel interface and all of the OSPF control packets undergo GRE encapsulation before entering the IPsec tunnels.
  • The default MTU value for a Layer 3 GRE tunnel in an Aruba controller is 1100. When running OSPF over a GRE tunnel between an Aruba controller and another vendor's router, the MTU values must be the same on both sides of the GRE tunnel.
Version history
Revision #:
1 of 1
Last update:
‎07-02-2014 05:08 PM
Updated by:
Labels (1)
Contributors
