What software packages are required for installing MMS on Red Hat Enterprise Linux ES 4?
Product and Software: This article applies to Aruba MMS and Red Hat Enterprise Linux ES 4.
Package Version
chkconfig any
fileutils any
redhat-lsb 1.3x
httpd 2.0.52x
selinux-policy-targeted-sources 1.17.30x
sendmail-cf 8.13.1x
compat-libstdc++-33 3.2.3x
JRE (provided on the MMS CD) 1.5.0x
The command used to check for these dependencies is:
rpm -qa | grep <name of the package>
For example:
[root@localhost ~]# rpm -qa |grep selinux-policy-targeted*
If the software package is not present or is not the right version, it can be added manually. Insert the Disk 4 of the Red Hat Installation Disk and add the package using the following command:
rpm -ivh <RPM name>
Version history
Revision #:
1 of 1
Last update:
‎07-10-2014 09:43 AM
Updated by:
Labels (1)
