What to configure on the controller for communication with Lync server?
Introduction : For communication between Lync server and Controller, configuration needs to be done both on the controller & Lync server.
Feature Notes : By means of Lync alg Controller is tighly bound with Lync server and the traffic classification is deterministic rather than just predictive. This provides accurate Voice quality metric to the controller.
Environment : Lync Voice, Video and File transfer applications are used in customer setup.
Network Topology : Controller ---- AP------ Laptop (Lync client)
Configuration Steps : To configure integration with the Lync server:
lync int
Answer : Controller IP address and port number have to configured on the Lync server.
Verification: (Abilash-Lab-Cont-master-6.4) #show web-server
Web Server Configuration
Parameter                                      Value
Cipher Suite Strength                          high
SSL/TLS Protocol Config                        sslv3 tlsv1
Switch Certificate                             default
Captive Portal Certificate                     default
IDP Certificate                                default
Management user's WebUI access method          username/password
User session timeout <30-3600> (seconds)       900
Maximum supported concurrent clients <25-320>  75
Enable WebUI access on HTTPS port (443)        false
Web Lync Listen Protocol/Port Config           http:15000
Troubleshooting : Use the below commands to enable debugging & troubleshoot Lync issues:
(Abilash-Lab-Cont-master-6.4) (config) #logging level debugging user process stm subcat voice
(Abilash-Lab-Cont-master-6.4) (config) #logging level debugging user process ucm
(Abilash-Lab-Cont-master-6.4) (config) #logging level debugging system process ucm
Version history
Revision #:
1 of 1
Last update:
‎07-03-2014 08:14 PM
Updated by:
Labels (1)
