What value must be selected for antenna when AP-85 is provisioned?
Product and Software: This article applies to Aruba AP-85.
AP-85 has four antenna connecting ports; two for 802.11a and two for 802.11g. If you have two antennas, one for 2.4 GHz and the other for 5 GHz, then you must select the following values:
  • If the antenna is connected to port1 of 802.11a or 802.11g, then 1 must be specified as the value.
  • If the antenna is connected to port2 of 802.11a or 802.11g, then 2 must be specified as the value.
  • If two antennas are connected to the 802.11a or 802.11g, then the "both" option must be specified.
AP "ARUBA" Provisioning Parameters
Item Value
AP Name ARUBA
AP Group ARB
Location name N/A
SNMP sysLocation N/A
Master 10.2.1.2
Gateway 10.2.1.1
Netmask 255.255.255.0
IP Addr 10.2.1.29
DNS IP N/A
Domain Name N/A
Server Name N/A
Server IP 10.2.1.2
Antenna gain for 802.11a 1
Antenna gain for 802.11g 1
Antenna for 802.11a both
Antenna for 802.11g both
Version history
Revision #:
1 of 1
Last update:
‎07-02-2014 05:19 PM
Updated by:
Labels (1)
Contributors
