Where to check 11ac Mesh Parent node selection logs?
Environment- 11ac Mesh in AOS 6.4.3
Answer- Mesh AP debug logs provides information about successfully scanned APs and their path cost:
[904]1969-12-31 16:00:38.705 meshd_set_link_cost: Using forward RSSI for mac: 00:24:6c:5a:82:88, fwd-rssi: 64, rev-rssi: 0. (max_rssi: 38), link-cost(cH):500
[904]1969-12-31 16:00:38.705 meshd_path_cost_compare: initialise first time to 00:24:6c:5a:82:88, path-cost(cH): 1600
[904]1969-12-31 16:00:38.705 meshd_set_link_cost: Using forward RSSI for mac: 6c:f3:7f:a8:95:30, fwd-rssi: 54, rev-rssi: 0. (max_rssi: 38), link-cost(cH):500
[904]1969-12-31 16:00:38.705 meshd_path_cost_compare: NEW link best (delta: 0). Old 00:24:6c:5a:82:88, pc(cH): 1600, RSSI: 64 (GOOD), hops: 2. New 6c:f3:7f:a8:95:30, pc(cH): 1300, RSSI: 54 (GOOD), hops: 1
[904]1969-12-31 16:00:38.705 Old: metric offset 0, path_cost 8, node_cost 0, cmp_adjust 3, link_cost 500, total path cost 1600, old poor 0
[904]1969-12-31 16:00:38.705 New: metric offset 0, path_cost 4, node_cost 2, cmp_adjust 2, link_cost 500, total path cost 1300, new poor 0
[904]1969-12-31 16:00:38.705 meshd_set_link_cost: Using forward RSSI for mac: 6c:f3:7f:7c:6d:31, fwd-rssi: 74, rev-rssi: 0. (max_rssi: 38), link-cost(cH):400
[904]1969-12-31 16:00:38.706 meshd_path_cost_compare: NEW link best (delta: 0). Old 6c:f3:7f:a8:95:30, pc(cH): 1300, RSSI: 54 (GOOD), hops: 1. New 6c:f3:7f:7c:6d:31, pc(cH): 1200, RSSI: 74 (GOOD), hops: 1
[904]1969-12-31 16:00:38.706 Old: metric offset 0, path_cost 4, node_cost 2, cmp_adjust 2, link_cost 500, total path cost 1300, old poor 0
[904]1969-12-31 16:00:38.706 New: metric offset 0, path_cost 6, node_cost 0, cmp_adjust 2, link_cost 400, total path cost 1200, new poor 0
[904]1969-12-31 16:00:38.706 meshd_rejecting_children: 94:b4:0f:2b:be:f1 rejecting, no_more_children: TRUE, subtree_full: FALSE, recovery: FALSE
[904]1969-12-31 16:00:38.706 meshd_scan_complete:427 set channel, chan: 161, offs: 0.
[904]1969-12-31 16:00:38.706 meshd_set_channel:189 change channel to 161/0
[904]1969-12-31 16:00:38.711 meshd_dfs_channel: check DFS for channel 161 result 0
Version history
Revision #:
1 of 1
Last update:
‎04-06-2015 04:12 AM
Updated by:
Contributors
