Which CLI command shows the user’s connection speed and the number of packets that have been sent or received?
Product and Software: This article applies to all Aruba controllers and ArubaOS 3.3.2.x and later.
If the user has slow connectivity, run this command to check at what speed the user is connected:
(Aruba200) #show ap debug client-table ap-name onyx-office-point
Client Table
MAC                ESSID       BSSID              Assoc_State  HT_State  AID  PS_State    UAPSD            Tx_Pkts  Rx_Pkts  PS_Qlen  Tx_Retries Tx_Rate  Rx_Rate  Last_ACK_SNR  Last_Rx_SNR  TX_Chains  Tx_Timestamp              Rx_Timestamp
00:26:b0:c0:af:4b  onyx-tiger  00:24:6c:c1:48:20  Associated   None      0x1  Power-save  (0,0,0,0,N/A,0)   50      148       0        2              54        54      38            39           2[0x5]     Mon Oct 18 16:23:12 2010  Mon Oct 18 16:23:12 2010
00:27:10:2c:2a:a4  onyx-tiger  00:24:6c:c1:48:20  Associated   RM        0x2  Power-save  (0,0,0,0,N/A,0)   8        24       0        0              78        1       52            53           2[0x5]     Mon Oct 18 16:23:13 2010  Mon Oct 18 16:23:14 2010
UAPSD:(VO,VI,BK,BE,Max SP,Q Len)
HT Flags: A - LDPC Coding; W - 40Mhz; S - Short GI; M - Max A-MSDU
          D - Delayed BA; G - Greenfield; R - Dynamic SM PS
          Q - Static SM PS; N - A-MPDU disabled
To determine what rates are being used, look at the client stats. Issue the "show ap debug client-stats <client-mac>" command to shows the number of packets that have been sent or received from a client at different PHY rates.
Example
(Aruba200) #show ap debug client-stats 90:84:0d:62:dd:0b
Station Stats
Parameter            Value
----------------     General Per-radio Statistics
----------------     Transmit Specific Statistics
Frames Rcvd For TX   31
Tx Frames Dropped    0
Frames Transmitted   31
Success With Retry   0
Tx Mgmt Frames       2
Tx Probe Responses   0
Tx Data Frames       29
Tx Data Bytes        11653
Tx CTS Frames        0
Dropped After Retry  0
Dropped No Buffer    0
Missed ACKs          0
Long Preamble        1
Short Preamble       30
Tx EAPOL Frames      11
Tx 1 Mbps            4
Tx 18 Mbps           10
Tx 24 Mbps           4
Tx 36 Mbps           5
Tx 48 Mbps           6
Tx 54 Mbps           2
Tx WMM [BE]          30
Tx WMM [VO]          3
UAPSD OverflowDrop   0
---------------- Receive Specific Statistics
Last SNR             51
Last SNR CTL0        50
Last SNR CTL1        45
Last SNR CTL2        39
Last ACK SNR         49
Last ACK SNR CTL0    48
Last ACK SNR CTL1    44
Last ACK SNR CTL2    36
Frames Received      52
Rx Data Frames       51
Rx Data Bytes        8431
Null Data Frames     4
Rx Mgmt Frames       1
PS Poll Frames       0
Rx 1 Mbps            11
Rx 54 Mbps           41
Rx WMM [BE]          47
Version history
Revision #:
1 of 1
Last update:
‎07-03-2014 09:45 AM
Updated by:
Labels (1)
Contributors
