Which power injectors are compatible with AP-124/125?
Product and Software: This article applies to the Aruba AP-124/125.
The PD-70xx series of power injectors are compatible with the Aruba AP-124/125:
PD-7001-AC      1 Port PowerDsine High Power PoE Midspan 10/100/1000
PD-7006-AC      6 Port PowerDsine High Power PoE Midspan 10/100/1000
PD-7012-AC      12 Port PowerDsine High Power PoE Midspan 10/100/1000
PD-7024-AC      24 Port PowerDsine High Power PoE Midspan 10/100/1000
Version history
Revision #:
1 of 1
Last update:
‎07-09-2014 11:30 AM
Updated by:
Labels (1)
Contributors
