Which serial number should I use for generating licenses for different types of controllers?What is the difference between the SC serial number and the system serial
Question:  Which serial number should I use for generating licenses for different types of controllers?What is the difference between the SC serial number and the system serial
Product and Software: This article applies to all Aruba controllers and ArubaOS versions.
When you activate the licenses for all chassis-based controllers, use the SC serial number and NOT the system serial number.
The Aruba M3 Controller Module, Aruba Supervisor Card II (SC2), and Aruba Supervisor Card I (SC1) are all chassis-based controller platforms. The SC serial number from the 'show inventory' command must be used to activate their licenses.
Examples
SC-II
#show inventory
Supervisor Card slot : 1
Supervisor FPGA : SCCI Rev 0x6
SC Assembly# : 2010004D (Rev:05.00)
SC Serial# : F00503580(Date:05/24/08)
Crypto Assembly# : 2000017C (Rev:91.00) (SC-II)
Crypto Serial# : F00544582
Mgmt Port HW MAC Addr : 00:0B:86:FF:14:D6
HW MAC Addr : 00:0B:86:00:5B:A0 to 00:0B:86:00:5B:11F
CPLD Version : 1 (Rev: 1)
PEER Supervisor Card : Present
Line Card 1 : Absent
Line Card 2 : Not accessible from this SC
Line Card 3 : Present
Line Card 3 FPGA : LCCI Rev 0x6
Line Card 3 Switch Chip : SwitchCore CXE-1000 Rev 0x3
Line Card 3 Mez Card : Present
Line Card 3 SPOE : Present
Line Card 3 Sup Card 0 : Present ( Active )
Line Card 3 Sup Card 1 : Present ( Active )
Line Card 3 Assembly# : 2000001C (Rev:03.00) (24FE+2GE)
Line Card 3 Serial# : P00000857 (Date:11/21/03)
Line Card 3 SPOE Assembly# : 2000003B (Rev:02.00) (SPOE-1)
Line Card 3 SPOE Serial# : S00000343
Line Card 3 MEZZ Assembly# : 2000002A (Rev:01.00)
Line Card 3 MEZZ Serial# : S00000294
FAN 0 : OK, Speed High
FAN 1 : OK, Speed High
FAN 2 : OK, Speed High
Fan Tray Assembly# : 00007B01 (Rev:02.00)
Fan Tray Serial# : S00000045 (Date:03/25/04)
Back Plane Assembly# : 2000006B (Rev:01.00)
Back Plane Serial# : A00000156 (Date:12/09/03)
Power Supply type : Power One (400W)
Power Supply 0 : OK (400W)
Power Supply 1 : Absent
Power Supply 2 : Absent
Internal Temperature : 28.00 degrees Celsius (NORMAL)
System 5.00V : Current reading 5.03 Volts (NORMAL)
System 3.30V : Current reading 3.30 Volts (NORMAL)
System 2.50V : Current reading 2.53 Volts (NORMAL)
CPU 2.00V : Current reading 2.00 Volts (NORMAL)
FPGA 1.80V : Current reading 1.80 Volts (NORMAL)
SERDES 1.80V : Current reading 1.80 Volts (NORMAL)
BCM1250 1.20V : Current reading 1.20 Volts (NORMAL
M3mk1
#show inventory
Mobility Processor : FPGA Rev 0x23120920
Mobility Processor Assembly# : 2010027B
Mobility Processor Serial# : F00558973
SC Assembly# : 2010026C (Rev:05.03)
SC Serial# : F00599497(Date:12/07/07)
SC Model# : M3mk1-128
Mgmt Port HW MAC Addr : 00:0B:86:61:00:74
HW MAC Addr : 00:0B:86:03:53:00 to 00:0B:86:03:53:7F
XPLD Version : (Rev: 20)
Line Card 0 : Present
Line Card 0 FPGA : FPGA Rev 0xFF
Line Card 0 Switch Chip : Broadcom 56308 Rev 0xF
Line Card 0 Mez Card : Present
Line Card 0 SPOE : Present
Line Card 0 Sup Card 0 : Present ( Active )
Line Card 0 Sup Card 1 : Present ( Active )
Line Card 0 Assembly# :
Line Card 0 Serial# :
Line Card 0 SPOE Assembly# :
Line Card 0 SPOE Serial# :
Line Card 0 MEZZ Assembly# :
Line Card 0 MEZZ Serial# :
Line Card 1 : Not accessible from this SC
Line Card 3 : Not accessible from this SC
Fan Tray Assembly# : 2000007C (Rev:01.00)
Fan Tray Serial# : F00067128 (Date:11/09/05)
Back Plane Serial# : A00001765 (Date:10/27/05)
M3mk1 Card Temperatures : M3mk1 card 36 C
: CPU 40 C
AMP Card Temperatures : Processor Card 30 C
: Mobility Processor 45 C
: M3mk1 CPU Fan Speed 6428 RPMs
M3mk1 Card Voltages : M3mk1 5000mV 5010 mV
: M3mk1 3300mV 3360 mV
: M3mk1 2500mV 2482 mV
: M3mk1 1800mV 1780 mV
: M3mk1 1500mV 1510 mV
: M3mk1 1250mV 1260 mV
: M3mk1 1200mV 1200 mV
: M3mk1 IBC 12000mV 11730 mV
: M3mk1 CPU CORE 1200mV 1210 mV
: M3mk1 XGMII VTT 750mV 760 mV
: M3mk1 VTT0(a&b) 900mV 900 mV
: M3mk1 VTT1(c&d) 900mV 900 mV
: AMP 3300mV 3360 mV
: AMP 2500mV 2500 mV
: AMP 1800mV 1820 mV
: AMP 1500mV 1520 mV
: AMP BCM 1200mV 1180 mV
: AMP FPGA 1200mV(1) 1200 mV
: AMP FPGA 1200mV(2) 1200 mV
For all the other controllers, Aruba 200, Aruba 800, Aruba 2400, Aruba 3000 series, and Aruba 600 series, use the system serial# for activating the licenses and NOT the SC Serial#.
If you use the SC serial# instead of the System Serial#, a "Failed to decrypt key" error is displayed. In this example, an evaluation certificate for a 3200 has been activated using SC serial number and not the system serial number:
#license add n8k+gd8T-F81cRzuf-WgIfRCyZ-edzjWq8u-7L5QfdTv-drM
Examples
Aruba 3200
#show inventory
Supervisor Card slot : 0
System Serial# : AC0004046
SC Assembly# : 2010029B (Rev:03.00)
SC Serial# : F01049408 (Date:11/25/08) //NOT TO BE USED
SC Model# : A3200
HW MAC Addr : 00:0B:86:61:4C:00 to 00:0B:86:61:4C:03
CPLD Version : (Rev: 1.1)
A3200 Card Temperatures :
: Card Temperature 32 C
: CPU Temperature 38 C
A3200 Fan Tachometers :
: Chassis Fan A 4000 RPM
: Chassis Fan B 4067 RPM
: Chassis Fan C 4000 RPM
: Chassis Fan D 3934 RPM
A3200 Card Voltages :
: VMON1 3300mV 3360 mV
: VMON2 2500mV 2550 mV
: VMON3 AB 1800mV 1822 mV
: VMON4 CD 1800mV 0 mV
: VMON5 1200mV 1218 mV
: VMON6 1000mV 996 mV
Aruba 200
(Aruba200) #show inventory
Supervisor FPGA : None
System Serial# : AA0004938
SC Assembly# : 2010024C (Rev:05.00)
SC Serial# : F00311549 (Date:01/16/07) //NOT TO BE USED
HW MAC Addr : 00:0B:86:60:16:2C to 00:0B:86:60:16:2D
Line Card 1 : Present
Line Card 1 FPGA : None
Line Card 1 Switch Chip : No Switch Chip
Line Card 1 Mez Card : Absent
Line Card 1 SPOE : Absent
Line Card 1 Sup Card 0 : Present ( Active )
Internal Temperature : 55
Aruba 2400
show inventory
Supervisor FPGA : SYRAH Rev 0x5
System Serial# : A20012255
SC Assembly# : 2010009D (Rev:10.00)
SC Serial# : F01390980 (Date:10/14/09) //NOT TO BE USED
HW MAC Addr : 00:0B:86:43:A7:40 to 00:0B:86:43:A7:5F
Line Card 1 FPGA : SYRAH Rev 0x5
Line Card 1 Switch Chip : SwitchCore CXE-1000 Rev 0xA
Line Card 1 SPOE : Present
Internal Temperature : 32
For all license generation and activation using ArubaOS 5.0 and later, the LMS issues a warning message if you use the SC serial for a non-chassis based controller. The error message states that the system does not exist. In this case, since the controller is a 620 (non-chassis based), you must use the system serial number and not the SC serial number.
Version history
Revision #:
2 of 2
Last update:
‎07-08-2014 11:15 AM
Labels (1)
Contributors
Tags (1)
