Which versions of ArubaOS are supported by AP-175 and which USB cable is needed to provision the AP-175?
Product and Software: This article applies to AP-175 and ArubaOS 5.0.2.1 and later.
AP-175 requires ArubaOS 5.0.2.1 or later.
To provision the AP-175 you need a USB 2.0 Cable, Standard Type A Male to Type A Male.
Version history
Revision #:
1 of 1
Last update:
‎07-02-2014 04:49 PM
Updated by:
Labels (1)
Contributors
