Why are my DHCP scopes running out faster "even" vlan pooling algorithm ?
MVP
MVP
Problem:
We have even vlan pooling algorithm enabled on the VAP. However we see that the DHCP scopes are running out faster with it.
Diagnostics:
1. We can configure Even vlan pooling algorithm as follows:
(Master)#config t
(Master) (config)# vlan-name first assignment even
(Master) (config) #vlan first 1,2
2. Verify the config:
(Master) (config) #show vlan mapping
Vlan Mapping Table
VLAN Name  Assignment Type  VLAN IDs
first      Even             1-2
We can view the VLAN assignment using the commands below. Outputs from these commands shouldn't vary too much:
1. #show vlan-assignment
VLAN Assignment
VLAN #CLIENTS
1 146
2 152
2. #show ap vlan-usage
VLAN Usage Table
VLAN ID  Clients
1 146
2 152
Solution
A client may be removed from the user table when:
1. Fails to authenticate for logon user lifetime.
2. Sends a de-auth to the AP.
3. Doesn't send any traffic for idle timeout duration.
When the same client connects again, it might be placed in a different vlan based on even vlan pooling algorithm. Now the number of users on the controller stays the same, however the same client is now using two scopes on the DHCP server in two different subenets. This causes the DHCP server to run out of IP leases faster.
Workaround:
Enable preserve-vlan in VAP profile. With this enabled, the controller will check in its datapath station table if the client already exists or not:
#show datapath station table
Flags: W - WEP, T - TKIP, A - AESCCM, M - WMM N - .11n client
       S - AMSDU, G - AESGCM, R - DATA READY, I - INACTIVE, r - ROAMED
       MAC              BSSID       VLAN Bad Decrypts Bad Encrypts RSN cap Aid  HomeVlan A-MsduSize A-MsduTxQ           Flags
34:A3:95:89:E8:56 18:64:72:D1:28:52  991            0            0    0000 0001      991          0 0000/0000/0000/0000   AMNR
EC:88:92:67:7C:C7 00:24:6C:11:7C:C2  991            0            0    0000 0005      991          0 0000/0000/0000/0000   AMNR
00:EE:BD:B1:C8:CD D8:C7:C8:96:C8:C8   24            0            0    0000 0002       24          0 0000/0000/0000/0000   MN
If the client already exists in the table, it will assign the same vlan to the client.
Version history
Revision #:
2 of 2
Last update:
‎02-23-2017 01:58 PM
Updated by:
Labels (1)
Contributors
