Why are wireless clients not able to authenticate using NTLM authentication?
Product and Software: This article applies to all Aruba Mobility Controllers and ArubaOS 3.4.1.
NTLM authentication is currently supported only for wired clients.
Wireless clients may be able to authenticate, but is not the intent for this feature and it is not supported by the deployment model.
Version history
Revision #:
1 of 1
Last update:
‎07-05-2014 03:31 AM
Updated by:
Labels (1)
