Why can't I configure AP125/AP124 as a remote AP in ArubaOS 3.2 or 3.3.1?
Question:  Why can't I configure AP125/AP124 as a remote AP in ArubaOS 3.2 or 3.3.1?
Product and Software: This article applies to all Aruba controllers and ArubaOS 3.2 and later.
While using ArubaOS 3.3.1 code, you cannot configure AP125 or AP124 as a remote AP. The remote AP feature will not be supported for AP125/AP124 until ArubaOS 3.3.2 code.
Version history
Revision #:
1 of 1
Last update:
‎07-04-2014 11:41 AM
Labels (2)
Contributors
